 Post subject: WD1200BEVS-00UST0 'Module 02 not found'
PostPosted: March 2nd, 2011, 10:33
I have a Western Digital 120GB WD1200BEVS-00UST0 which spins up fine, but cannot be seen when attached to a computer.
I attached the drive to PC-3000 and ran the WDC Marvell utility. The diagnostics run fine and I get output that the SA dir reading is 'Ok' however directly after this, I get:
"Configuration reading......................... : Module 02 not found"
The drive comes out of busy mode and the drive ID is read fine. The one thing I did notice is that when I read the modules from the service area I only get a list of about 4 modules. I ran the 'Module search in SA' feature and it then gives me a full list of modules which I then used within the utility and managed to read them all out. I tried writing them back to the drive but I can't seem to get rid of this error.
Any ideas?
 Post subject: Re: WD1200BEVS-00UST0 'Module 02 not found'
PostPosted: March 2nd, 2011, 11:55
Which PC3000?
PCI or UDMA?
PC has poor support for Marvel drives
PostPosted: March 2nd, 2011, 12:11
It's PC-3000 UDMA
PostPosted: March 3rd, 2011, 9:35
Perform Head Test..............
PostPosted: March 4th, 2011, 2:07
The rom error
Users browsing this forum: skinbob and 96 guests
