Can't access ST31000340AS
Posted: January 5th, 2011, 5:49
by Hee
Hi.
Patient hdd is ST31000340AS
Hdd initialize fine.
But can’t access after almost LBA 275000000.
Before 275000000, sector access fine.
When I copy in DE, after 275000000 sectors are black cells.
What is problem?
SA or FW?
How can i fix it?
Re: Can't access ST31000340AS
Posted: January 5th, 2011, 11:39
by hddguy
Did you try translator repair before?
Basically you have errors on surface stopping translator load correctly. Defects should be restored back to defect list. Can be done manual only I think, not sure of automatic process for it.
Posted: January 19th, 2011, 15:36
by _TK_
translator failure (m0,2,2,,,,,22) or defective head.
check heads first.
