HDD GURU FORUMS
http://forum.hddguru.com/
Hitachi HTS541612J9SA00 SA problem ?
http://forum.hddguru.com/viewtopic.php?f=11&t=18601
Page 1 of 1
Author:  kum4r [ February 17th, 2011, 9:58 ]
Post subject:  Hitachi HTS541612J9SA00 SA problem ?
Hi
I need help for recovery data from Hitachi HTS541612J9SA00.
I connect it to PC3000 Udma and power on. The Hdd go to ready but utility do not recognize the Hdd Family.
I manual select family and start utility and i get this:
Loading data for correction of HDD family handling settings from section MEM_P
Selected family......................... : HTS5416J9
Model by ID............................. : <ID IS NOT READ>
Techno mode key......................... : Ok
NV-RAM reading.......................... : Ok
Module not read (RESF)
Error : Device error detected (ABR)
Loading modules table................................................. : Error
Error :............................................................... : Module not read (RESF)
Loading the table of "open" modules................................... : Error
Error :............................................................... : Error executing loading "open" modules dir command
Module ZONE is not found!
Module is not loaded (RESF, Main module table)
When i'm try to make a SA Check i've get this:
Test : Start SA checking
Module checking
Module RSVD Copy 0...................... : Error
Module RSVD Copy 1...................... : Error
Drive not ready
Please give me some advice, what can i do with this hdd ?
Thank you.
http://www.phpbb.com/
