| WD1200BEVS-00UST0 'Module 02 not found' http://forum.hddguru.com/viewtopic.php?f=11&t=18729 |
Page 1 of 1 |
| Author: | JAllmanTalbot [ March 2nd, 2011, 10:33 ] |
| Post subject: | WD1200BEVS-00UST0 'Module 02 not found' |
I have a Western Digital 120GB WD1200BEVS-00UST0 which spins up fine, but cannot be seen when attached to a computer. I attached the drive to PC-3000 and ran the WDC Marvell utility. The diagnostics run fine and I get output that the SA dir reading is 'Ok' however directly after this, I get: "Configuration reading......................... : Module 02 not found" The drive comes out of busy mode and the drive ID is read fine. The one thing I did notice is that when I read the modules from the service area I only get a list of about 4 modules. I ran the 'Module search in SA' feature and it then gives me a full list of modules which I then used within the utility and managed to read them all out. I tried writing them back to the drive but I can't seem to get rid of this error. Any ideas? |
| Author: | pcimage [ March 2nd, 2011, 11:55 ] |
| Post subject: | Re: WD1200BEVS-00UST0 'Module 02 not found' |
Which PC3000? PCI or UDMA? PC has poor support for Marvel drives |
| Author: | JAllmanTalbot [ March 2nd, 2011, 12:11 ] |
It's PC-3000 UDMA |
| Author: | microsoftengineer [ March 3rd, 2011, 9:35 ] |
Perform Head Test.............. |
| Author: | zhujinx168 [ March 4th, 2011, 2:07 ] |
The rom error |
