| WD1600JB Module Header Error http://forum.hddguru.com/viewtopic.php?f=11&t=18740 |
Page 1 of 1 |
| Author: | hddnb [ March 3rd, 2011, 13:34 ] |
| Post subject: | WD1600JB Module Header Error |
Hello Gurus, Could any one please have a look at the following log and give a direction to fix it using PC-3000 UDMA? Model: WDC WD1600JB-00GVA0 Donor PCB with the ROM from the orignal burned PCB Status: still cannot be recognized by computer In PC-3000 UDMA: Get ready after 40 seconds Heads test....ok Resorce backup, some errors in -19 and -20 Cyl SA Structure Test: Some module errors --------------------------------------------------- Techno mode key: HDD geometry loading.................... : Ok Cyl Count............................... : 83970 Head Count.............................. : 4 SPT..................................... : 900 RAM: Zone allocation table................... : Ok ROM version............................. : 08.E4. SA FW version........................... : 08.E4D Link table version...................... : 02.GA. Serial ROM: Read ROM................................ : Ok Heads configuration..................... : From map Heads number............................ : 6 The number of heads in use.............. : 4 Disabled heads.......................... : Yes Head map................................ : 0,1,4,5 Service area: Modules table loading................... : Ok (Copy 0) Configuration loading................... : Ok Master Password......................... : "WDCWDCWDCWDCWDCWDCWDCWDCWDCWDCWD" User Password........................... : has not been set Translation overlay checking............ : Ok HDD resources backup ........................... : Ok Reading service tracks Everything ok except. . . Cyl -19; Head 1......................... : Ok WD Techno Read Error C/H/S: -20/0/1 Device Error Detected 59/01 (AMN) WD Techno Read Error C/H/S: -20/0/11 Device Error Detected 59/01 (AMN) Cyl -20; Head 0......................... : Ok WD Techno Read Error C/H/S: -20/1/1 Device Error Detected 59/01 (AMN) WD Techno Read Error C/H/S: -20/1/10 Device Error Detected 59/01 (AMN) WD Techno Read Error C/H/S: -20/1/11 Device Error Detected 59/01 (AMN) Cyl -20; Head 1......................... : Ok Backup process completed SA surface verification Initial cylinder........................ : -1 Final cylinder.......................... : -20 Head.................................... : 0,1 WD Techno Read Error C/H/S: -20/0/1 Device Error Detected 59/01 (AMN) WD Techno Read Error C/H/S: -20/0/11 Device Error Detected 59/01 (AMN) WD Techno Read Error C/H/S: -20/1/1 Device Error Detected 59/01 (AMN) WD Techno Read Error C/H/S: -20/1/10 Device Error Detected 59/01 (AMN) WD Techno Read Error C/H/S: -20/1/11 Device Error Detected 59/01 (AMN) SA surface verification completed Heads test Cylinder to test........................ : -25 Heads to test........................... : 0,1,4,5 Head 0.................................. : Ok Head 1.................................. : Ok Head 4.................................. : Ok Head 5.................................. : Ok SA structure test Module 3C Copy 0........................ : Header error Module 3C Copy 1........................ : Header error Module 38 Copy 0........................ : Header error Module 38 Copy 1........................ : Header error Module 30 Copy 0........................ : Header error Module 30 Copy 1........................ : Header error Module 34 Copy 0........................ : Header error Module 34 Copy 1........................ : Header error Module 45 Copy 0........................ : Header error Module 45 Copy 1........................ : Header error Module 01 Copy 0........................ : Header error Module 01 Copy 1........................ : Header error Module 10 Copy 0........................ : Header error Module 10 Copy 1........................ : Header error Module 22 Copy 0........................ : Header error Module 22 Copy 1........................ : Header error Module 23 Copy 0........................ : Header error Module 23 Copy 1........................ : Header error Module 46 Copy 0........................ : Header error Module 46 Copy 1........................ : Header error SA structure checking has been completed Reading modules Into folder............................. : <HDD Profile>\Data\Modules\ Reading method.......................... : Composite reading All Modules : ............................. : Ok Reading service tracks Into folder............................. : <HDD Profile>\Data\Tracks Reading heads........................... : 0,1 All OK except: WD Techno Read Error C/H/S: -20/0/1 Device Error Detected 59/01 (AMN) WD Techno Read Error C/H/S: -20/0/11 Device Error Detected 59/01 (AMN) Cyl -20; Head 0......................... : Ok WD Techno Read Error C/H/S: -20/1/1 Device Error Detected 59/01 (AMN) WD Techno Read Error C/H/S: -20/1/10 Device Error Detected 59/01 (AMN) WD Techno Read Error C/H/S: -20/1/11 Device Error Detected 59/01 (AMN) Cyl -20; Head 1......................... : Ok |
| Author: | harddrivespecialist [ March 3rd, 2011, 15:18 ] |
| Post subject: | Re: WD1600JB Module Header Error |
Some messed up SA. |
| Author: | guru [ March 3rd, 2011, 16:49 ] |
Imagine a surgeon injecting you with general anaesthesia, while you count down from 5 to 1 you hear him ask "What does a scalpel look like?" |
| Author: | hddnb [ March 3rd, 2011, 18:01 ] |
Thanks, you guys. Seems no cure for this patient. |
| Author: | harddrivespecialist [ March 3rd, 2011, 20:42 ] |
There is a cure, but have to work with it. |
| Author: | hddnb [ March 8th, 2011, 11:24 ] |
I got all the data. Thanks. |
