 Post subject: WD5000AAKS-00WWPA Module 11
PostPosted: May 26th, 2011, 9:20
Good morning to all,
I need module 11 for WD5000AAKS-00WWPA. Has anyone got it? Thanks for advance!
ROM version............................. : 00.1GB
ROM generation.......................... : 00.1GB
Link table version...................... : 03.0C.
Caclulated Version...................... : 0000001G
 Post subject: Re: WD5000AAKS-00WWPA Module 11
PostPosted: May 30th, 2011, 9:25
Hi
Do you steel need this module?
I have one of this drives in stock I can try to see if have the same ROM version.
Let me know if you steel need.
PostPosted: May 31st, 2011, 4:28
Hello
ROM:
Flash Dir reading....................... : Ok
Dir info (0B)........................... : 0 (24)
Extended flash Dir reading.............. : Ok
Dir info (20B).......................... : 156 333 (24)
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM generation.......................... : 00.1HB
This is the module you asked.
http://www.megaupload.com/?d=P8OZEZ7I
