Request For Module 11
http://forum.hddguru.com/viewtopic.php?f=11&t=19741
Author:  Cleanroom [ June 17th, 2011, 14:45 ]
Post subject:  Request For Module 11
looking for module 11
WD5000AAKS - 22V1A0
Firmware - 0012001E
Tahoe Family
thanks
Author:  F_ARG [ June 17th, 2011, 15:34 ]
Post subject:  Re: Request For Module 11
Good Morning,
Try this one
WD5000AAKS-00V1A0-05-01D05
RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1290
>ROM:
>Flash Dir reading....................... : Ok
>Dir info (0B)........................... : 78 910 (24)
>Extended flash Dir reading.............. : Ok
>Dir info (20B).......................... : 24 (24)
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 12.1ED
>ROM generation.......................... : 12.1FD
>Link table version...................... : 04.09.
>Caclulated Version...................... : 0012001E
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Head map................................ : 0,1
>ROM Firmware version.................... : 0012000M
>Service area:
>SA dir reading.......................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.rar [348 Bytes]
Downloaded 434 times
Author:  Cleanroom [ June 17th, 2011, 15:54 ]
Does not work , It shows as being 0012000M
Thanks for the file
anyone else :)
edit - I forgot to say that the file is blank. open it up in a hex editor and it is all zeros.
Author:  thatdellguy [ June 17th, 2011, 15:55 ]
I looked, dont have...
Author:  F_ARG [ June 17th, 2011, 17:30 ]
"edit - I forgot to say that the file is blank. open it up in a hex editor and it is all zeros"
ups, sorry man...i didn t check it before send. :oops:
I don t have other here.... If i find one i ll send it.
Sorry again
Author:  einstein9 [ June 18th, 2011, 13:23 ]
WD5000AAKS - 22V1A0
Firmware - 0012001E
Tahoe Family
thanks
can u tell me ur drive SN?
Author:  einstein9 [ June 18th, 2011, 13:34 ]
man i was looking in my storage n DB and every damn corner there is NO 22V1A0
none :oops:
