WD1200BB-00DAA3 Unknown issue
Posted: July 4th, 2011, 10:38
Hi
I have a WD1200BB-00DAA3 that first he just made the heads clicking noises..
With a drive form the same family I was able to make a hotswap and save all the modules and SA tracks.
After that I connect the donor drive and copy the A and AS modules from the original drive. I made the hotswap again and this time I was able to read the sector 0. I open a task in data extractor but each time I tried to read other sector the drive stops reading. I tried a couple of times but all the times I was just able to read the sector 0.
What I did next was connect the donor drive again and copy all the B modules but when I power off/power on the drive never detect again.
Because I didn´t have other drive from this family to repair the one that gets damaged I replace the heads. After I replace the heads I was able to recognize the drive and create a task in data extractor but I have kind of the same problem again, I was just able to read the first sector.
Anyone already got a issue like this?
Do you guys have some suggestions?
