 Post subject: Problem at my hard disk
PostPosted: July 9th, 2011, 10:00
I have a problem in Hard Disk Has become does not work and change the name of the
wd320
To
modelpinclite
I can not solve this problem
pls help me all my data base in this hard disk
 Post subject: Re: Problem at my hard disk
PostPosted: July 12th, 2011, 23:10
Need to run some more tests using working compatible parts to identify the issue(s).
Although there can be other issues, frequently this family drives have firmware issues. This requires more expensive professional equipment to search for problem more thoroughly.
PostPosted: July 13th, 2011, 10:38
wd320
To
modelpinclite
This is the ROM identifying as opposed to the correct info from the SA.
Probably you have damage to overlay.
You have SA access?
Users browsing this forum: No registered users and 21 guests
