| Barracuda ES 2 Bussy problem http://forum.hddguru.com/viewtopic.php?f=11&t=19979 |
Page 1 of 1 |
| Author: | fanys [ July 13th, 2011, 5:21 ] |
| Post subject: | Barracuda ES 2 Bussy problem |
Barracuda ES 2 Bussy problem I have his hard drive Barracuda ES2 ST3250310NS PCB (ZKAJ-7) PCB 100475720REV A hard drive spin up may remain bussy I tried 2 solutions: 1.isolating spindle motor controller 2.short check point to PCB But not have succes At the terminal not responding "Reply time out" and motor not spin up In the PC 3k Udma appear Model: ST_M13FQBL Serial: QNR_BFW Firmware: 11291209 Capacity: 3.86 Gb The drive have HP firmware Can you please help |
| Author: | hddguy [ July 13th, 2011, 7:58 ] |
| Post subject: | Re: Barracuda ES 2 Bussy problem |
fanys wrote: At the terminal not responding "Reply time out" and motor not spin up Maybe the problem is obvious?? |
| Author: | einstein9 [ July 13th, 2011, 8:02 ] |
connect it to ur UDMA and open HT then power ON and Ctrl-Z in terminal see if u can get anything from there 1st. |
| Author: | hddguy [ July 13th, 2011, 8:03 ] |
ES2 will not give response at CTRL+Z unless are operating normal. |
| Author: | einstein9 [ July 13th, 2011, 8:11 ] |
hddguy wrote: ES2 will not give response at CTRL+Z unless are operating normal. i guess ur right on this |
| Author: | fanys [ July 14th, 2011, 4:24 ] |
hddguy wrote: ES2 will not give response at CTRL+Z unless are operating normal. Really not responding the hard drive its OEM manufactured for seagate from HP it has firmware HPG2 mdl hp: GB0250C8045(date 13.09.2008) its from dedicate workstation( raid server) was buyng with customer at secon hand and reinstallated windows xp from stand allone workstation Off! Off! I looked on HP site firmware update from this hard drive but before this operation must be upgradet raid controller (instructions HP site) but I have problems with data ?(Off! Off!) Anny help??? |
