 Post subject: I Need Help
PostPosted: August 29th, 2011, 16:52
im have a WD3200AAJS-07RYA0 (320GB - 22/JUN/2007) and need the firmware for use it, the hdd pcb crash and explode the smoth IC, im use a other pcb of WD3200AAJS, but only obtain clicks...
if possible you can give me this firmware?
and i need other firmware (same fail) of WD2500JS-60NCB1 (250GB - 10/SEPT/2006)
best regards =)
 Post subject: Re: I Need Help
PostPosted: August 30th, 2011, 9:37
firmware version
PostPosted: August 30th, 2011, 10:00
Sometimes Preamp also gets damage due to damaged pcb . You should check preamp.
PostPosted: August 30th, 2011, 10:14
http://files.hddguru.com/index.php?acti ... igital/JS&
PostPosted: August 30th, 2011, 10:52
try to download patent settings from PCB
