 Post subject: ST2000DL001 2TB connection drops after working for a while
PostPosted: August 2nd, 2011, 17:41
Hello All,
Does anyone has solution for this situation? Is it heads issue or others? It just works for a couple of minutes and gets offline.
 Post subject: Re: ST2000DL001 2TB connection drops after working for a whi
PostPosted: August 4th, 2011, 3:53
hi,
may be if you can explain a little bit more someone can help you, what do you mean with
can you read up to a specific LBA and then you get errors?
let us know
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: August 4th, 2011, 10:26
It means I can copy some files when the hard drive is connected to the computer and then the computer says the hard drive is unpluged. Within PC3k, the hard drive works for a while and then no spinning.
PostPosted: August 4th, 2011, 14:08
chk ur PCB does it go over heat in top of the Diodes? i mean the other side
