| ST2000DL001 2TB connection drops after working for a while http://forum.hddguru.com/viewtopic.php?f=11&t=20167 |
Page 1 of 1 |
| Author: | hddnb [ August 2nd, 2011, 17:41 ] |
| Post subject: | ST2000DL001 2TB connection drops after working for a while |
Hello All, Does anyone has solution for this situation? Is it heads issue or others? It just works for a couple of minutes and gets offline. |
| Author: | irs [ August 4th, 2011, 3:53 ] |
| Post subject: | Re: ST2000DL001 2TB connection drops after working for a whi |
hi, may be if you can explain a little bit more someone can help you, what do you mean with Quote: It just works for a couple of minutes and gets offline. can you read up to a specific LBA and then you get errors? let us know Bye Luca |
| Author: | hddnb [ August 4th, 2011, 10:26 ] |
It means I can copy some files when the hard drive is connected to the computer and then the computer says the hard drive is unpluged. Within PC3k, the hard drive works for a while and then no spinning. |
| Author: | einstein9 [ August 4th, 2011, 14:08 ] |
chk ur PCB does it go over heat in top of the Diodes? i mean the other side |
