 Post subject: WD800JD-60JRA0 ROM Recovery
PostPosted: August 6th, 2011, 4:07
Good day
All Guru's i have WD800JD-60JRA0 original ROM was Currepted someone worked on it before me now original is missing i have Rewritten Compatable ROm from Donor HDD Detects with Model, Capacity & Serial No. reading all modules and CYl's not allowing to access SA Model Heads Test is ok any Help will be appreciated thanks in advance.
 Post subject: Re: WD800JD-60JRA0 ROM Recovery
PostPosted: August 8th, 2011, 4:12
hi,
sorry but i don't understand some things:
what do you mean with "compatible ROM"? did you rebuild it from SA?
you say you read modules and tracks but you can't access SA ... so what can you read?
If you can read mods you can also rebuild original ROM so you don't need to bother with mod11 compatibility and ROM mod47
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
Users browsing this forum: No registered users and 95 guests
