 Post subject: WD400BB-00DEA0 defect SA
PostPosted: August 10th, 2011, 8:21
Can somebody help me? I can just Copy a little bit of the Data.
 Post subject: Re: WD400BB-00DEA0 defect SA
PostPosted: August 10th, 2011, 8:41
That's synonymous with, "Car doesn't work right, can someone tell me how to fix through a post".
In other words, you need to provide more information before anyone will be able to help.
PostPosted: August 10th, 2011, 8:54
sorry guys, seems that the SA is damaged. I shows me SA defect and also it show me during the copy BAD MFT.
PostPosted: August 10th, 2011, 10:02
WHAT do you intend for SA? I have a feeling...
PostPosted: August 10th, 2011, 10:12
Can you attach SA report? Do you have access to sectors at all?
PostPosted: August 19th, 2011, 11:39
Do you have native PCB here? Maybe head map or head count is wrong.
Just a guess tho, so many potential problems more info is needed.
Can you read SA at both copies? Are there any obvious errors? You say about bad MFT, is this because surface is not accessible?
Can you confirm translator is OK?
Users browsing this forum: No registered users and 88 guests
