HDD GURU FORUMS
http://forum.hddguru.com/
Looking for Samsung HM500JI ROM
http://forum.hddguru.com/viewtopic.php?f=11&t=20341
Page 1 of 1
Author:  newaustralian [ August 21st, 2011, 23:11 ]
Post subject:  Looking for Samsung HM500JI ROM
Hi Guys,
Can anybody please help with a ROM for the following dive
HM500JI , was manufactured on 16/10/2010
2Acc4yeB.d20 was found in the FSI module.
This HDD has a burnt MCU.
I did a hotswap procedure but got corrupted file system and majority of files was also corrupted (Maybe I didn’t copy all required modules).
So I hope that Rom and you, Guys, will help to get data back.
Thanks.
Author:  labtech [ August 21st, 2011, 23:14 ]
Post subject:  Re: Looking for Samsung HM500JI ROM
What tool are you using for hot swap and data access?
Author:  BlackST [ August 22nd, 2011, 0:28 ]
newaustralian wrote:
Hi Guys,
Thanks.
Doesn't work this way.
Author:  newaustralian [ August 22nd, 2011, 2:01 ]
Thanks Guys for your replies.
The tool is PC3000.
Thanks.
Author:  labtech [ August 22nd, 2011, 10:42 ]
First, must clarify the ROM situation. It is confusing regarding the problem you are dealing with.
*Look in the UDMA manual and you should see what modules are critical for your model drive.
Author:  newaustralian [ August 22nd, 2011, 19:24 ]
Dear Labtech,
Ok, I'll try to explain. ROM's gone together with the PCB so as I understand I have two options. The first one is to do a hot swap, but this, it seems, doesn’t work (also the manual doesn’t have any information regarding this Samsung family yet). The second one is to get a compatible ROM and using another PCB get access to data.
Do you have any experience with this HDD model?
Thanks.
Author:  labtech [ August 22nd, 2011, 19:41 ]
Not any more experience than other Samsung models, but same fundamentals apply regardless of support. What I do know is that sometimes they are really picky and tricky to get to work.
Is your donor pcb not compatible enough to get the target drive to work?
Author:  newaustralian [ August 22nd, 2011, 21:27 ]
Thanks Guys.
Eventually all data has been saved using a hot swap procedure.
http://www.phpbb.com/
