HTS541
Posted: September 5th, 2011, 6:28
by ici_lemmy
I'm experiencing problems with an HTS541 drive.
The PC3000 cannot ID the drive and return that :
- Code:
Loading modules table................................................. : Ok
Loading the table of "open" modules................................... : Error
Error :............................................................... : Error executing loading "open" modules dir command
I think that these modules are required for the initialisation of the HDD.
Can somebody help me with this ?
Re: HTS541
Posted: September 5th, 2011, 9:18
by dmarques
Probably some main modules are damaged.
Have you checked them?
Probably PSHT.
Re: HTS541
Posted: September 5th, 2011, 10:34
by ici_lemmy
PSHT was damages but i was able to repair it. And the result is the same !
EDIT : DUMP is also damaged but importance is D so i didn't touch it !
Re: HTS541
Posted: September 5th, 2011, 10:43
by dmarques
You say that you repaired it.
So that means that one of the copies was good? Or did you rebuilt manually and copied it to the drive?
After power reset, can you read PSHT just fine in both copies?
DUMP doesn't matter.
Re: HTS541
Posted: September 5th, 2011, 10:49
by ici_lemmy
Copy 0 and 1 are bad (unreadable sector) but Factory copy was good.
So I modified module RESF with the adress of PSHT of factory copy.
Am I wrong of doing that this way ?
EDIT : after power OFF/on, copy 0 is good and copy 1 and factory are bad !
Re: HTS541
Posted: September 5th, 2011, 11:00
by dmarques
Ok.
So if you have copy0 fine, even if you don't get an ID, you should be able to access LBA.
Have you tried it?
Re: HTS541
Posted: September 5th, 2011, 11:32
by ici_lemmy
Yes i tried and it doesn't work !
Re: HTS541
Posted: September 5th, 2011, 11:43
by dmarques
So something is wrong with SA yet.
Are you sure when you changed RESF, you didn't shift any other modules?
Re: HTS541
Posted: September 5th, 2011, 11:58
by ici_lemmy
I'll check that.
Anyway, I think I'll send an email to PC3000 support et post here what was the problem when i find it !
Re: HTS541
Posted: September 5th, 2011, 12:30
by dmarques
Another option can be also to relocate SA.
Re: HTS541
Posted: September 6th, 2011, 11:34
by ici_lemmy
Copying user data right now...
Thanks to Ace support who showed me this topic
http://acelaboratory.ru/forum/viewtopic.php?f=30&t=7186 (you have to be logged in)
Thanks to dmarques too.
Re: HTS541
Posted: September 6th, 2011, 12:40
by dmarques
Ok. SA relocation solved it
Re: HTS541
Posted: September 7th, 2011, 3:02
by ici_lemmy
I wouldn't say it was just "SA relocation" like you would do it with the WD dir editor...
Re: HTS541
Posted: September 7th, 2011, 5:09
by dmarques
Glad you solved it anyway.
