 Post subject: Terminal output after head change
PostPosted: September 5th, 2011, 15:19
Seagate 7200.10, terminal output after head change. Any hints? Drive stays on busy mode.
MR
$SFI
AMR
$$$SFI
AMR
(P)SATA Reset
$SFI
AMR
$$$SFI
AMR
$$$SFI
AMR
$$$SFI
AMR
DiskAccess ReadSector EC=47 at ffffffff.00.0002
$SFI
AMR
$SFI
AMR
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Retrys
Read Ver Failure!
DiskAccess ReadSector EC=47 at ffffffff.00.022b
Failed sys sect. write! Nwt Er 00 RdWr 16645.00.022b
DiskAccess ReadSector EC=47 at ffffffff.00.0080
Unable To Load Overlay 01|000A
T>
 Post subject: Re: Terminal output after head change
PostPosted: September 5th, 2011, 16:43
was it dropped initially? Did you swap heads "manually" or with a tool?
Data Recovery Ireland
PostPosted: September 5th, 2011, 17:16
You still can try to initilize it using a loader.
PostPosted: September 5th, 2011, 17:46
Yes, according to the client it really was dropped. And the heads were changed "manually".
PostPosted: September 5th, 2011, 17:48
Ok, great. And please, the suitable loader I can find from where?
PostPosted: September 5th, 2011, 17:49
From another drive with same model and firmware at least.
PostPosted: September 5th, 2011, 17:54
So I'm looking for a loader for Seagate 7200.10 with FW 3.AFD, please.
PostPosted: September 5th, 2011, 17:57
I'm not in the office, so I cannot check now. Will check tomorrow.
PostPosted: September 5th, 2011, 18:24
Great, thanks in advance.
PostPosted: September 7th, 2011, 2:09
Do you think the surface is damaged because of dropping?
PostPosted: September 8th, 2011, 1:36
Out of curiosity, have you noticed a wobble while manually rotating the platters? Also, upon powering, does it make a click sound or more of a chirp sound?
PostPosted: September 15th, 2011, 6:19
No noticeable wobbling. It's pretty much a kind of chirp.
PostPosted: September 20th, 2011, 21:40
Sent PM.
PostPosted: September 25th, 2011, 5:08
Case closed. The drive was recognized after some fiddling the screw and it is cloned totally. Thank you.
Users browsing this forum: Majestic-12 [Bot] and 86 guests
