 Post subject: NOKIA CA-42
PostPosted: November 15th, 2011, 4:56
please upload the driver for NOKIA CA-42 cable, want to use with seagate,
thanks
 Post subject: Re: NOKIA CA-42
PostPosted: November 15th, 2011, 10:08
hi
i think you wrote on the wrong session, here is for PC3000 support so if you need to use the nokia cable for terminal in seagate you should try on another place.
I can't help you as i don't use that cable to work.
Bye
Luca
Data Recovery pro in Italy
www.ultrarecovery.com
PostPosted: November 15th, 2011, 14:59
The CA-42 cable comes in all different flavours, each with a potentially different USB-serial bridge IC. The internal cabling is not consistent either, although the pinout of the Pop-port is fixed.
Here is the pinout of a Nokia Pop-port:
http://pinouts.ru/CellularPhones-Nokia/ ... nout.shtml
You need to use pins 6, 7, and 8.
To identify the bridge chip, you could use Microsoft's UVCView utility:
http://www.users.on.net/~fzabkar/USB_ID ... ew.x86.exe
The Vendor ID and Product ID will probably identify the bridge manufacturer, in which case you may find drivers on their web site.
PostPosted: November 15th, 2011, 16:49
This is spoon feeding now! :x
PostPosted: November 16th, 2011, 15:56
I should add that the Product ID (PID) and Vendor ID (VID) may be visible in the Properties for the device in Device Manager.
A Google search turns up several repositories of USB IDs:
http://www.google.com/search?q=%22usb+ids%22
Here is one that I have extracted from UVCView:
http://www.users.on.net/~fzabkar/USB_ID ... id_nam.txt
