 Post subject: WD DENALI
PostPosted: November 16th, 2011, 13:52
Hi to all!
After an exchange of the HDD heads respond well ...
Denali
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 128
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 08.2CD
ROM generation.......................... : 08.2CD
Link table version...................... : 02.14.
Consolidated ROM version................ : 0008002C
ROM Modules:
Flash ROM dir reading................... : Ok
Modules directory address............... : FIXED
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
ROM Firmware version.................... : 0008002C
Нет ничего невозможного
 Post subject: Re: WD DENALI
PostPosted: November 17th, 2011, 8:45
sempre wrote:
Hi to all!
Denali
Techno mode key
RAM:
ROM:
ROM Modules:
PostPosted: November 17th, 2011, 16:48
It's in kernel mode, so no SA access.
Drive remains spinning after coming DRDY?
PostPosted: November 18th, 2011, 6:38
pcimage wrote:
It's in kernel mode, so no SA access. Ok!
Yes!!
No SA acess normal mode...
PostPosted: November 18th, 2011, 9:07
Hi!
Does it have original PCB?
Best regards
F.
PostPosted: November 20th, 2011, 6:53
Yes!!
What happens when you try normal mode?
PostPosted: November 21st, 2011, 7:59
pcimage wrote:
Yes!!
echno mode key
RAM:
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM Modules:
Service area:
SA dir reading.......................... : Unknown error. Code(0)
SA Access............................... : NONE
Configuration reading................... : Module 02 not found
Upload LDR ERROR => OVM ERR NOT COMPATIBLE
PostPosted: November 22nd, 2011, 12:20
You have alternative compatible loader?
PostPosted: November 22nd, 2011, 17:28
I had the same issue with a Denali recently, same behaviour after headswap. Used a loader and got access to SA and all data.
Data Recovery Cape Town
PostPosted: November 23rd, 2011, 6:43
Not..
Please send me Loader!
Hdd model WD1600BEVT-75ZCT2
PostPosted: November 23rd, 2011, 10:04
I looked but i only have 00zct0 and 22zct0 available. :(
PostPosted: November 23rd, 2011, 10:08
Does HD remain powered? IF so select 'View Module 90 information' and it should give to you the SA version.
If ROM is native then version is 0008002C. Is PCB/ROM native?
PostPosted: November 23rd, 2011, 10:23
Got lots from ZC family but not 0008002C. Sorry.
PostPosted: November 24th, 2011, 1:31
Try this resource.
http://files.hddguru.com/download/PC-3000-UDMA%20Support/WDC%20Marvell%20family%20utility/Denali/WD1600BEVT-00ZCT0%2011.01A11%20WD-WXE409PL5076.rar
PostPosted: April 26th, 2012, 4:51
Backup Rom and use recovery Rom function. If still can't not identify, use LDR loading function.
Best Regards,
SkypID: hddselftest
Email: hddselftest@gmail.com
PostPosted: April 26th, 2012, 6:11
From what I can see ROM seems native, and LDR not an option because no compatible version is available...
Hotswap and read patient 11.rpm could be option, but post is very old now...
Users browsing this forum: No registered users and 14 guests
