HD082GJ with module´s problem.
http://forum.hddguru.com/viewtopic.php?f=11&t=21245
Author:  twuska [ November 25th, 2011, 21:47 ]
Post subject:  HD082GJ with module´s problem.
How can i fix this problem using pc3k-pci v2.4???
Tks
Author:  twuska [ November 26th, 2011, 8:56 ]
Post subject:  Re: HD082GJ with module´s problem.
What´s the first step to detect module's problem???
Author:  labtech [ November 26th, 2011, 13:20 ]
Pc3k comes with manual. Check it out. Plenty of info there.
Author:  hddguy [ November 29th, 2011, 12:52 ]
You need to explain your problem in more detail. The more generic you are the less of a response you will get back.
Also as you have PCI PC3000 you should check it actually supports the model of HDD you are working with.
Author:  twuska [ December 4th, 2011, 6:22 ]
tks for all
