HDD GURU FORUMS
http://forum.hddguru.com/
Seagate ST3500820AS diganosis help
http://forum.hddguru.com/viewtopic.php?f=11&t=21451
Page 1 of 1
Author:  aribot [ December 15th, 2011, 8:18 ]
Post subject:  Seagate ST3500820AS diganosis help
Could you help me in diagnosis?
When the hard drive is powered, spins up and headstack makes some cliks. After 20 seconds it spins down.
PCB malfunction is discarted because we have tried with donor and hapens the same.
We suspect could be spin motor malfunction, but head problems could be possible? How to know the problem?
Thanks.
Author:  microsoftengineer [ December 15th, 2011, 10:13 ]
Post subject:  Re: Seagate ST3500820AS diganosis help
HI
Aribot if you are using Pc3000 you have to look in Terminal Log it shows you what is the Error in that HDD, according to me it has Heads issue Probably Scratches on platters.
Author:  aribot [ December 16th, 2011, 9:37 ]
One of the results in Terminal is:
F3 T>/2
F3 2>U
Error 1009 DETSEC 00006008
Spin Error
Elapsed Time 39.159 secs
R/W Status 2 R/W Error 84150180
Next week I'll open it in the lab, and check heads and platter surface. I'll tell you!
Thanks.
Alex.
Author:  northwind [ December 16th, 2011, 10:13 ]
I can smell bad heads from here..
http://www.phpbb.com/
