SDLD algorithm
Posted: January 3rd, 2012, 0:25
by selftest
Hi everybody,
Through Seagate user manual, in chapter 6.2 The "Tools" --> "Utillity extensions" menu, i saw term "SDLD, block checksum". Who can tell me what SDLD algorithm is, or any document about SDLD algorithm ?
Thank you very much.
Re: SDLD algorithm
Posted: January 3rd, 2012, 3:04
by guru
That is something that you will need to reverse yourself :@)
Re: SDLD algorithm
Posted: January 3rd, 2012, 3:14
by selftest
Hi Guru,
Thanks for your reply.
With checksum formula in WD HDD, or Seagate (byte sum, word sum) i can understand but with SDLD, this is a problem. Any advice for me ?
Re: SDLD algorithm
Posted: January 3rd, 2012, 3:55
by Vorian
The algorithm is known and was published on a russian forum
http://www.lmgtfy.com/?q=%D1%81%D0%B4%D0%BB%D0%B4+xor
Re: SDLD algorithm
Posted: January 3rd, 2012, 4:05
by selftest
Vorian wrote:The algorithm is known and was published on a russian forum
Oh, Thanks a lot for your sharing.
I will try to understand Russian.
Thanks again.
Re: SDLD algorithm
Posted: January 3rd, 2012, 4:08
by selftest
Hi Vorian,
Thanks a lot of for your sharing, i will try to understand Russian forum.
Re: SDLD algorithm
Posted: January 3rd, 2012, 4:12
by guru
That spoils the fun of learning :@(
Re: SDLD algorithm
Posted: January 3rd, 2012, 4:19
by selftest
Hi guru,
I have spend 1 week for SDLD algorithm to analyze, and the result is still zero. Have a lot of checksum algorithm but with SDLD, this is the first i hear about it. :((
Re: SDLD algorithm
Posted: January 3rd, 2012, 4:22
by guru
http://forum.ru-board.com/topic.cgi?for ... &start=400
Looks good also talks about handshake ;@) which is required
Re: SDLD algorithm
Posted: January 3rd, 2012, 21:29
by selftest
Thanks Vorian and guru again, i understood it. If you didn't tell about it for me, maybe i drop out. :(
