Page 1 of 1
FUJITSU MHZ drivelock recovery
Posted: January 31st, 2012, 20:26
by dav781
Hello Everyone,
I must unlock a Fujitsu MHZ2160BH, the drive lock security state is high. wiping data is not an option, since i must recover the content of disk.
I am ready to pay for solution, either a new firmware, with fw writing tool, or the description of an alternative system to go around drive lock for this particular model.
I tried traditional boot cd hacks, also tried swapping hd at last moment, when selecting a new password from (original hp laptop) bios. none worked.. still locked.
If you have a working solution for salvaging data, Please send Your quotation,
thanks,
David
Re: FUJITSU MHZ drivelock recovery
Posted: February 1st, 2012, 2:32
by poehere
If you can prove this is your HDD contact BlackST in Italy he should be able to help you with this one. He can unlock the HDD but only if you can prove that it is yours for security reasons on this one. Send him a PM
Posted: February 1st, 2012, 9:20
by hddguy
dav781 wrote:I am ready to pay for solution,
I think you will have more success in paying for professional recovery. The process will likely involve the use of hardware that you probably dont have that will prove to be too expensive for a single PW unlock.
