| Seagate momentus 5400.6 firmware problem http://forum.hddguru.com/viewtopic.php?f=11&t=21928 |
Page 1 of 1 |
| Author: | michael chiklis [ February 2nd, 2012, 15:16 ] |
| Post subject: | Seagate momentus 5400.6 firmware problem |
Hello. I've this Momentus 5400.6 ST9500325AS hard drive which is no more detected by bios. Firmware version: 0001SDM1 I tried the firmware unlock procedure as the barracuda 7200.11 with the RS232/TTL adapter and now the bios of my computer detects it again. But there is a problem, the drive is very slow and hdd regenerator detect all bad sector after LBA 55834000 (about 27 GB) From 0 to 55834000 LBA is all fine and working good, but after sector 55834000 hdd regenerator give's me all bad sectors. Of course, it's not a bad sector problem, but something about translator modules in the firmare http://www.msfn.org/board/topic/145751- ... -solution/ I need pc-3000 to repair it or something similar, or any other ideas. Someone can help me? t is possible to repair with chipper software as SeDiv ? |
| Author: | pcimage [ February 3rd, 2012, 16:01 ] |
| Post subject: | Re: Seagate momentus 5400.6 firmware problem |
It is translator issue, usually fixable in UDMA. UDMA has an "automated" fix for this, but it can also be done manually via the serial port. So it probably can be done via SeDiv or similar, but you have to know the commands AND how to use them properly. |
| Author: | CK [ February 3rd, 2012, 20:15 ] |
HDD Regenerator? |
| Author: | michael chiklis [ February 3rd, 2012, 20:41 ] |
Hello pcimage, what is udma ? Do you know the commands for translator fix ? It is possible with hyper terminal ? I have also pc3000 dos version without the pci card |
| Author: | hddguy [ February 6th, 2012, 5:02 ] |
michael chiklis wrote: what is udma ? Do you know the commands for translator fix ? It is possible with hyper terminal ? I have also pc3000 dos version without the pci card Seek professional assistance. I think will be best chance for your data. |
| Author: | michael chiklis [ February 8th, 2012, 6:52 ] |
I've tried to contact SeDiv on IRQ but he doesn't answer. How can i buy SeDiv software if he doesn't answer ? |
| Author: | pcimage [ February 8th, 2012, 17:24 ] |
michael chiklis wrote: Hello pcimage, what is udma ? Do you know the commands for translator fix ? It is possible with hyper terminal ? I have also pc3000 dos version without the pci card UDMA = PC3000 UDMA from Ace Laboratory Russia Yes I do, and sorry I won't tell you Yes maybe with a lot of manual work and knowledge The more you screw with this drive, the less your chances of recovery are. Sorry to say this, but it's the truth |
| Author: | michael chiklis [ February 8th, 2012, 18:48 ] |
pcimage wrote: Yes I do, and sorry I won't tell you
