HDD GURU FORUMS
http://forum.hddguru.com/
WD10TMVW-11ZSMS1 problem
http://forum.hddguru.com/viewtopic.php?f=11&t=22015
Page 1 of 1
Author:  F_ARG [ February 9th, 2012, 21:11 ]
Post subject:  WD10TMVW-11ZSMS1 problem
Hello!
I have this hdd WD10TMVW-11ZSMS1 that is identified by OS as 0 bytes. I connect it using serial port to PC3K. I can access to WD application using 115200 baud rate, but not faster. I can see that all modules are fine and i can make a sector edit without error all around the hdd, but it s encrypted by sym chip. I try with WD Smartware but the hdd is not found. Someone got any clue? I think i am missing something...
Best regards,
F
Author:  pcimage [ February 10th, 2012, 3:00 ]
Post subject:  Re: WD10TMVW-11ZSMS1 problem
Please try not to double post, I have already replied to the same post in another section.
Thank you
http://www.phpbb.com/
