 Post subject: WD3200AAKS-75L9A0 FW+ROM
PostPosted: February 22nd, 2012, 14:26
Hi to all!!
Necessary is ROM+MODS ALL
WD3200AAKS-75L9A0
DATE:13 MAR 2010
infos hdd
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 170
>Zone allocation table................... : Ok
>SA SPT.................................. : 1311
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 05.F9E
>ROM generation.......................... : 05.F9E
>Link table version...................... : 04.0F.
>Consolidated ROM version................ : 000500F9
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Modules directory address............... : FIXED
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>ROM Firmware version.................... : 000500F9
>Service area:
>SA dir reading.......................... : Ok
>SA Access............................... : Copy 1
>Configuration reading................... : Ok
Нет ничего невозможного
 Post subject: Re: WD3200AAKS-75L9A0 FW+ROM
PostPosted: February 22nd, 2012, 18:14
What is actual problem?
PostPosted: February 23rd, 2012, 8:22
not initialize the SA CLICKING...
not initialize the SA BEFORE CLICKING had bad modules (21,22,31,32,2e,6f, 121) CLICKING
PostPosted: February 23rd, 2012, 10:29
I send you modules, but i don t have ROM.
Best regards,
F
WDC WD3200AAKS-00L9A0 01.03E01 WD-WCAV2R504030.rar [3.58 MiB]
Downloaded 628 times
PostPosted: May 3rd, 2012, 22:51
Best regards,
F
Addtion for F_ARG, this is Rom.
00500F9.zip [181.15 KiB]
Downloaded 437 times
Best Regards,
SkypID: hddselftest
Email: hddselftest@gmail.com
