 Post subject: Can't restore WD Royl drive after using it for smart hotswap
PostPosted: March 2nd, 2012, 14:21
I used a WD20EARS-0MVWB0 to smart hot swap a similar drive (it worked, that's done). The problem I'm having and often have after smart hotswap (moving all patient tracks to donor) is restoring the drive back to it's original state.
I always just try writing all the service tracks back to the drive, but it often either doesn't finish or gets too slow to finish, like writing 1 track every 10 hours.
With this current drive, I tried writing it's original backup tracks back. It took about 20 hours to move them all back (at first was fast, then got slower towards the end). Now the drive comes ready with no ID and no SA copy available:
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 6
Cyl Count............................... : 256
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 22.00E
ROM generation.......................... : 22.00E
Link table version...................... : 0B.36.
Consolidated ROM version................ : 00220000
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 377 654 (24)
SA regions address...................... : by default
Heads number in use..................... : 6
Switched off heads...................... : No
Heads map............................... : 0,1,2,5,6,7
ROM Firmware version.................... : 00220000
Service area:
SA dir reading (ID)..................... : Ok
SA Access............................... : NONE
Configuration reading................... : No SA copy avalabled
Trying to write tracks says I need a Loader. I've tried every loader in DB (including the original loader for this drive and the patient drive), but all give some error and do not work.
What else can I try?
More importantly, can some expert out there provide the (or "their") proper procedure to restore donor tracks back to donor so its working again after smart hotswap?
Thanks!
-Brian
