Need ROM and ROM modules from WD..Rom version: 000500CV
http://forum.hddguru.com/viewtopic.php?f=11&t=22527
Author:  hdrescue [ March 29th, 2012, 6:14 ]
Post subject:  Need ROM and ROM modules from WD..Rom version: 000500CV
Hello guys
I need a ROM and ROM modules from WD10EAVS-00D7B1 Rom version: 000500CV
I will be really appreciate.
Author:  hdrescue [ April 2nd, 2012, 7:03 ]
Post subject:  Re: Need ROM and ROM modules from WD..Rom version: 000500CV
Hi
No one with this ROM version?
Author:  positivebit [ April 2nd, 2012, 15:32 ]
try this :D
ROM.zip [177.46 KiB]
Downloaded 610 times
Author:  hddguy [ April 3rd, 2012, 5:45 ]
Why cant you restore ROM from SA?
Author:  hdrescue [ April 4th, 2012, 10:35 ]
positivebit Thanks a lot for the ROM. I´m making some tests.
hddguy When I do the hot swap to copy the modules I can copy all the modules from copy 0 but for some reason the modules are not in the right positions.. and I´m using the one drive with the same model and same family(Kermit).
Do you have any idea why this is happening? If you need I can send you the modules..
