 Post subject: Toshiba MK3265GSX
PostPosted: April 11th, 2012, 13:26
i am getting this (Attached)error in pc3000 portable ,
Unable to read HDD ID,BSY,DRD and DSC glows,
I also have donor PCB. What might be issue?
Thanks to all gurus in advance
 Post subject: Re: Toshiba MK3265GSX
PostPosted: April 11th, 2012, 18:30
Does HDD Spin?
Is CableSelect mode set?
How does drive behave? Any noise?
Can you attach terminal?
Is PCB original? These are not interchangeable without modification.
Data Recovery Ireland
PostPosted: April 12th, 2012, 15:34
YES HDD Spins
No Noise Like head issue
terminal attached
Original PCB
PostPosted: April 13th, 2012, 9:27
I do not see cableselect in udma /portable
I have few toshibas some of them give drd dsc initially but while entering utility stays busy with same error.
PostPosted: April 13th, 2012, 13:07
Did not found cable select option in pc3000 portable.
is this option available with portable?
PostPosted: April 13th, 2012, 15:20
I have no experience with portable version so can't comment.
On full version, it's under Tools menu.
