Toshiba MK3265GSX
http://forum.hddguru.com/viewtopic.php?f=11&t=22647
Author:  DRCP [ April 11th, 2012, 13:26 ]
Post subject:  Toshiba MK3265GSX
i am getting this (Attached)error in pc3000 portable ,
Unable to read HDD ID,BSY,DRD and DSC glows,
I also have donor PCB. What might be issue?
Thanks to all gurus in advance
Author:  CK [ April 11th, 2012, 18:30 ]
Post subject:  Re: Toshiba MK3265GSX
Does HDD Spin?
Is CableSelect mode set?
How does drive behave? Any noise?
Can you attach terminal?
Is PCB original? These are not interchangeable without modification.
Author:  DRCP [ April 12th, 2012, 15:34 ]
YES HDD Spins
No Noise Like head issue
terminal attached
Original PCB
Author:  TaskManager [ April 13th, 2012, 9:27 ]
I do not see cableselect in udma /portable
I have few toshibas some of them give drd dsc initially but while entering utility stays busy with same error.
Author:  DRCP [ April 13th, 2012, 13:07 ]
Did not found cable select option in pc3000 portable.
is this option available with portable?
Author:  CK [ April 13th, 2012, 15:20 ]
I have no experience with portable version so can't comment.
On full version, it's under Tools menu.
