 Post subject: WD DENALI
PostPosted: November 16th, 2011, 13:52
Hi to all!
After an exchange of the HDD heads respond well ...
Denali
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 128
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 08.2CD
ROM generation.......................... : 08.2CD
Link table version...................... : 02.14.
Consolidated ROM version................ : 0008002C
ROM Modules:
Flash ROM dir reading................... : Ok
Modules directory address............... : FIXED
Heads configuration..................... : by map
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
ROM Firmware version.................... : 0008002C
Нет ничего невозможного
 Post subject: Re: WD DENALI
PostPosted: November 17th, 2011, 8:45
sempre wrote:
Hi to all!
Denali
Techno mode key
RAM:
ROM:
ROM Modules:
PostPosted: November 17th, 2011, 16:48
It's in kernel mode, so no SA access.
Drive remains spinning after coming DRDY?
PostPosted: November 18th, 2011, 6:38
pcimage wrote:
It's in kernel mode, so no SA access. Ok!
Yes!!
No SA acess normal mode...
PostPosted: November 18th, 2011, 9:07
Hi!
Does it have original PCB?
Best regards
F.
PostPosted: November 20th, 2011, 6:53
Yes!!
What happens when you try normal mode?
PostPosted: November 21st, 2011, 7:59
pcimage wrote:
Yes!!
echno mode key
RAM:
Zone allocation table................... : HDDs RAM reading error - Device Error Detected: "VSCE PERM OVL NOT LOADED. LDR Upload is recomended"
ROM:
ROM Modules:
Service area:
SA dir reading.......................... : Unknown error. Code(0)
SA Access............................... : NONE
Configuration reading................... : Module 02 not found
Upload LDR ERROR => OVM ERR NOT COMPATIBLE
PostPosted: November 22nd, 2011, 12:20
You have alternative compatible loader?
PostPosted: November 22nd, 2011, 17:28
I had the same issue with a Denali recently, same behaviour after headswap. Used a loader and got access to SA and all data.
Data Recovery Cape Town
PostPosted: November 23rd, 2011, 6:43
Not..
Please send me Loader!
Hdd model WD1600BEVT-75ZCT2
PostPosted: November 23rd, 2011, 10:04
I looked but i only have 00zct0 and 22zct0 available. :(
PostPosted: November 23rd, 2011, 10:08
Does HD remain powered? IF so select 'View Module 90 information' and it should give to you the SA version.
If ROM is native then version is 0008002C. Is PCB/ROM native?
PostPosted: November 23rd, 2011, 10:23
Got lots from ZC family but not 0008002C. Sorry.
PostPosted: November 24th, 2011, 1:31
Try this resource.
http://files.hddguru.com/download/PC-3000-UDMA%20Support/WDC%20Marvell%20family%20utility/Denali/WD1600BEVT-00ZCT0%2011.01A11%20WD-WXE409PL5076.rar
PostPosted: April 26th, 2012, 4:51
Backup Rom and use recovery Rom function. If still can't not identify, use LDR loading function.
Best Regards,
SkypID: hddselftest
Email: hddselftest@gmail.com
PostPosted: April 26th, 2012, 6:11
From what I can see ROM seems native, and LDR not an option because no compatible version is available...
Hotswap and read patient 11.rpm could be option, but post is very old now...
