| ST31500341AS http://forum.hddguru.com/viewtopic.php?f=11&t=22778 |
Page 1 of 1 |
| Author: | sempre [ April 26th, 2012, 14:02 ] |
| Post subject: | ST31500341AS |
Hi to all!! Head 00 Resistance 00E5 Head 01 Resistance 0101 Head 02 Resistance 015F Head 03 Resistance 0107 Head 04 Resistance 00D3 Head 05 Resistance 0110 Head 06 Resistance 01D2 Head 07 Resistance 0144 Good heads?? |
| Author: | loki [ April 26th, 2012, 14:33 ] |
| Post subject: | Re: ST31500341AS |
Why not go into the universal util & do a head map & then run a express test. Then you will see if all heads are reading ok Loki |
| Author: | loki [ April 26th, 2012, 15:10 ] |
loki wrote: Why not go into the universal util & do a head map & then run a express test. Then you will see if all heads are reading ok Loki Looks like the head map feature in express tests is in the beta version they used in training? |
