 Post subject: WD10EAVS-32D7B1 Rom version 000500C5 Loder needed
PostPosted: April 29th, 2012, 9:48
Hello
I turn on this drive and it get ready but don´t recognize the ID info.. With a hot swap I was able to copy the tracks and convert them to modules but the module 11 (LDR) is missing so I think if I get a compatible LDR I can detect the hard drive and recover the data.
Let me know if some one can get this LDR.
 Post subject: Re: WD10EAVS-32D7B1 Rom version 000500C5 Loder needed
PostPosted: May 1st, 2012, 20:29
hdrescue wrote:
Hello
Here for you. Hope it is helpful for your working.
RG,
Skype: hddselftest
Email: hddselftest@gmail.com
11.zip [145.39 KiB]
Downloaded 403 times
Best Regards,
SkypID: hddselftest
PostPosted: May 4th, 2012, 10:05
Hello
Thanks selftest but this loder was from a 000500AS version. This is not compatible.
Someone can supply this loder?
PostPosted: May 22nd, 2012, 8:06
hi,
000500AP i have. please feel free to contact me by email or skype if need. thanks.
data recovery service[/b]
PostPosted: May 31st, 2012, 9:05
Hello
Thanks but from that version I have it to.
I´m still looking for this loder, I was able to read all the firmware beside the module 11.
With out it I can´t do anything. I tried to do a smart swap with other drive but the result was negative.
PostPosted: June 1st, 2012, 8:25
hdrescue wrote:
I was able to read all the firmware beside the module 11....
Either you make hotswap wrong, or there is other problem somewhere else.
PostPosted: June 1st, 2012, 12:47
Try this...
">Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 6
>Cyl Count............................... : 170
>Zone allocation table................... : Ok
>SA SPT.................................. : 1325
>ROM:
>Flash Dir reading....................... : Ok
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 05.C5E
>ROM generation.......................... : 05.C5E
>Link table version...................... : 04.3F.
>Heads configuration..................... : by map
>Heads number in use..................... : 6
>Switched off heads...................... : No
>Head map................................ : 2,3,4,5,6,7
>ROM Firmware version.................... : 000500BM
>Service area:
>SA dir reading.......................... : Ok
>SA Copies avalabled..................... : Copy 0,Copy 1
>Configuration reading................... : Ok
>Master Password......................... : has not been set
>User Password........................... : has not been set
!SA Firmware version..................... : 000500C5
11.rar [140.32 KiB]
Downloaded 432 times
PostPosted: June 14th, 2012, 13:46
Sorry guys.. I just saw this messages today..
hddguy
The problem is that I´m using a drive from different rom version.. I can do all precess until I try to copy all the modules..
pcimage
Thanks for the reply. I tried to use it but is not compatible.
Still looking to find the same rom version or I can accept ideas :)
PostPosted: June 23rd, 2012, 4:00
Here it is if you still need it.
11.rar [140.33 KiB]
Downloaded 426 times
Users browsing this forum: No registered users and 14 guests
