 Post subject: changing heads on Seagate ST31000528AS disk remains bsy
PostPosted: April 30th, 2012, 16:27
after changing the heads to the Seagate ST31000528AS disk remains BSY.
I tried to run the utility to resolve the problem but did not give any results
Has anyone had the same problem?
 Post subject: Re: changing heads on Seagate ST31000528AS disk remains bsy
PostPosted: May 1st, 2012, 8:38
What utility for what problem?
PostPosted: May 4th, 2012, 18:35
i've used TESTS -> SOLUTIONS -> Solution for problem "HDD LOCK (LED: 000000CC)
the disk today have started
but in the translator regeneration is going to BSY situation
in this moment don't start
