HDD GURU FORUMS
http://forum.hddguru.com/
changing heads on Seagate ST31000528AS disk remains bsy
http://forum.hddguru.com/viewtopic.php?f=11&t=22809
Page 1 of 1
Author:  popotamo [ April 30th, 2012, 16:27 ]
Post subject:  changing heads on Seagate ST31000528AS disk remains bsy
after changing the heads to the Seagate ST31000528AS disk remains BSY.
I tried to run the utility to resolve the problem but did not give any results
Has anyone had the same problem?
Author:  BlackST [ May 1st, 2012, 8:38 ]
Post subject:  Re: changing heads on Seagate ST31000528AS disk remains bsy
What utility for what problem?
Author:  popotamo [ May 4th, 2012, 18:35 ]
i've used TESTS -> SOLUTIONS -> Solution for problem "HDD LOCK (LED: 000000CC)
the disk today have started
but in the translator regeneration is going to BSY situation
in this moment don't start
http://www.phpbb.com/
