| Help!! Lost Data Extractor'001514 Key .. http://forum.hddguru.com/viewtopic.php?f=11&t=23046 |
Page 1 of 1 |
| Author: | reynanvills [ May 25th, 2012, 5:58 ] |
| Post subject: | Help!! Lost Data Extractor'001514 Key .. |
Hello! Can somebody help-- I've change my operating system from WINDOWS 2000 into WINDOWS XP PRO. I reinstall PC 3000 and everything work perfect except the data extractor 001514 that i've lost my key. Hopefully anyone out there can help me. Thank you in advance.. |
| Author: | hddguy [ May 25th, 2012, 6:09 ] |
| Post subject: | Re: Help!! Lost Data Extractor'001514 Key .. |
If its genuine, Acelab will help. |
| Author: | reynanvills [ May 25th, 2012, 6:10 ] |
Okay! thank you for advice. Il contact ace lab |
| Author: | reynanvills [ May 27th, 2012, 22:36 ] |
Ace Lab did'nt reply or advice about this matter. Does anyone out there have a key for "Data Extractor"?Pls pm .. Thank You in advance . appreciate your help. |
| Author: | poehere [ May 28th, 2012, 1:56 ] |
Look in your download box and your key is there in a txt doc. All keys for your tools are in your download box. I just checked mine and this is correct. No need to contact ACE on this one. Login and download it then reinstall it. |
| Author: | einstein9 [ May 28th, 2012, 2:20 ] |
reynanvills wrote: Ace Lab did'nt reply or advice about this matter. Does anyone out there have a key for "Data Extractor"?Pls pm .. Thank You in advance . appreciate your help. as hddguy said If its genuine, Acelab will help. but if u got this from someone, Good Luck |
| Author: | northwind [ May 28th, 2012, 3:58 ] |
reynanvills wrote: Does anyone out there have a key for "Data Extractor"? |
| Author: | Nick_CT [ May 28th, 2012, 4:07 ] |
reynanvills wrote: Ace Lab did'nt reply or advice about this matter. I highly doubt that. |
| Author: | einstein9 [ May 28th, 2012, 4:45 ] |
I dono why am suspecting this is a tool which been bought from someone (or somewhere) and most probably reynanvills is not the 1st. original buyer. if that is the case my dear, i suggest you go n read their policy " Once you buy it, it should DIE with you" no more support from any type will be provided by them and best thing you can do is 1 or 2 Option 1: Get a nice FRAME for it, and hang it on your room - coz it worth a lot. Option 2: You may sell it or get rid of it (since its useless without Lic.) and sure my dear you will find many people interested on buying it and will do Option 1 (am the 1st.) thank you and good luck When you buy a Ferarri without the Key ( no chance of getting it from the Manufacturer again ) all what you can do is parking it on your front door and daily look @ it OR get rid of it and close subject, |
| Author: | poehere [ May 28th, 2012, 14:33 ] |
Reading this one again this is wrong. It did not work correctly. I am sorry this is BS on this one. When you install the software there is a very long code that has to be entered into this in order to move forward. The UDMA and DE use the same software and the key has to match and the card has to be installed when the software is being installed. Then before you can use it and during installation a code is generated to send to the activation server. This has to be saved during the installation on this one. Once you have the program installed you go to the activation server and give them this code. Then the activation server gives you another one back. You then bring up the program and point to this key. Then the tool is activated. YOU CAN NOT INSTALL THE UDMA OR THE UDMA + DE WITHOUT THE KEY. It will not work. Plus on top of this the key is in your DOWNLOAD BOX. I know this one too. If you do have the UDMA from ACE go to your download box and DOWNLOAD THIS KEY. You have to have this key in order to install any part of the software on this. While installing this software a key is generated on each install to activate the software again. You have to have this key to go to the activatino server to active this tool. Each time you reinstall this tool the procedure is the same. Sorry I know for a fact this one is correct. So even if you get a key from another peson it will not match your card and it will not work. SORRY. I feel like you do not have a legal tool to use. |
