 Post subject: WD10EARS-00MVWB1 FW Vers: 00200076 Module#32 Request
PostPosted: June 19th, 2012, 6:13
Hi everybody
I need module#32 for WD10EARS-00MVWB1 FW Vers: 00200076
The drive is from family Sadle G6
Heads number in use..................... : 4
Switched off heads...................... : Yes
Heads map............................... : 1,5,6,7
ROM Firmware version.................... : 00200076
If someone has this, please give me
Thank you in advance :D
 Post subject: Re: WD10EARS-00MVWB1 FW Vers: 00200076 Module#32 Request
PostPosted: June 23rd, 2012, 7:24
attached you have 11 and 32 from WD20EARS-00MVWB1 - FW Vers: 00200076
WD20EARS-00MVWB1.rar [330.44 KiB]
Downloaded 401 times
PostPosted: June 25th, 2012, 0:11
Thank you so much slack for your file. :D
