| SP4002H ROM NEEDED! http://forum.hddguru.com/viewtopic.php?f=11&t=23294 |
Page 1 of 1 |
| Author: | N.C. [ June 22nd, 2012, 8:30 ] |
| Post subject: | SP4002H ROM NEEDED! |
Hello friend, I am looking for more ROM images for this old Samsung drive SP4002H. Rev. A made: Korea 2003. 04 I have only in stock QU100-60 which is not compatible. If i am right, i need QU100- ? ( < 60 ), but not sure. The original ROM chip is dead on the pcb. Thank you Janos |
| Author: | GreyDKang [ June 22nd, 2012, 11:06 ] |
| Post subject: | Re: SP4002H ROM NEEDED! |
If rom is dead, preamp dead too. You need only burn resource for head material used. |
| Author: | N.C. [ June 25th, 2012, 4:43 ] |
GreyDKang wrote: If rom is dead, preamp dead too. You need only burn resource for head material used. The HDA is working, i have another drive for donnor, but the ROM is different and the patient goes to DBG> all the time. I can write in the ROM with programmer, but i need more versions to match at least one. The patient PCB is working, only the ROM chip dead. |
