 Post subject: wd3200aaks-75lao
PostPosted: June 27th, 2012, 18:04
Has anyone found the faults on thePCB(2060-701590-00 rev a)was working ok just stop spinning i can still get into kernel mode and install loader but will not spin so i cannot read sa
Has anyone got the answer or diagram ?
 Post subject: Re: wd3200aaks-75lao
PostPosted: June 28th, 2012, 2:46
Was working ok?
Do you mean me day it was workng fine and now it is dead?
Does it spin the drive at all and then spin down?
PostPosted: July 7th, 2012, 20:07
When the platters are severly damaged, it will happen.
PostPosted: July 8th, 2012, 16:09
Any chance you tried to write new ROM to it?
PostPosted: July 8th, 2012, 16:11
Are you referencing the case in this post
anyone-kind-enough-share-with-firmware-for-this-drive-t23396.html
Where you already try writing firmware from your db to it??
PostPosted: July 10th, 2012, 1:50
Did you try changing pcb ?
Users browsing this forum: No registered users and 122 guests
