Discussions related to PC-3000
Please no pirated software here!
Loader needed - WD RE WD1602ABKS-70N8A0 (GB0160EAPRR)
June 26th, 2012, 6:44
Hi Guys,
Looking for a loader for the above drive, bit of an oddball I know.......but if anyone can help, I'd really appreciate it... :D
F/W HPG0
Many thanks.....
Steve...
Re: Loader needed - WD RE WD1602ABKS-70N8A0 (GB0160EAPRR)
June 27th, 2012, 7:43
Hi Steve,
You didn't say which version you needed.
Try this one...
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>Zone allocation table................... : Ok
>Cyl Count............................... : 170
>SA SPT.................................. : 1311
>Head number reading..................... : Ok
>Heads number............................ : 1
>ROM:
>Flash Dir reading....................... : Ok
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 05.8VD
>ROM generation.......................... : 05.92D
>Link table version...................... : 04.AH.
>Heads configuration..................... : by map
>Heads number in use..................... : 1
>Switched off heads...................... : No
>Head map................................ : 0
>ROM Firmware version.................... : 0005008V
>Service area:
>SA dir reading.......................... : Ok
>SA Copies avalabled..................... : Copy 0
>Configuration reading................... : Ok
>Master Password......................... : has not been set
>User Password........................... : has not been set
!SA Firmware version..................... : 00050092
11.rar
(323.8 KiB) Downloaded 481 times
June 27th, 2012, 7:44
Or this...
>Techno mode key
>RAM:
>HDD Info reading........................ : Ok
>ROM:
>ROM version............................. : 05.A8D
>ROM generation.......................... : 05.A9D
>Link table version...................... : 04.AM.
>Consolidated ROM version................ : 000500A8
>ROM Modules:
>Flash ROM dir reading................... : Ok (Active)
>Modules directory address............... : 48 285 (24)
>SA regions address...................... : by default
>Heads map............................... : 0
>ROM Firmware version.................... : 000500A8
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.rar
(328.27 KiB) Downloaded 561 times
June 27th, 2012, 8:48
Thanks Sean,
I'll give em a try.... :D
September 25th, 2012, 10:21
Touchclarity, Did you finish this case ? I got one of these today..... :wink:
