 Post subject: Need mo #11 WD1600AAJS-75M0A0
PostPosted: November 8th, 2012, 3:29
Hello all,
Need help for module 11 of WD1600AAJS-75M0A0, with info as following
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 1
>Cyl Count............................... : 170
>ROM:
>ROM reading............................. : Ok
>ROM Data size........................... : 192 Kb
>ROM version............................. : 05.F9E
>ROM generation.......................... : 05.F9E
>Link table version...................... : 04.0F.
>Consolidated ROM version................ : 000500F9
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Modules directory address............... : FIXED
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 1
>Switched off heads...................... : No
>Heads map............................... : 0
>ROM Firmware version.................... : 000500F9
I have checked mods from hddguru files section, no match
Thanks,
 Post subject: Re: Need mo #11 WD1600AAJS-75M0A0
PostPosted: November 8th, 2012, 5:08
I have a WDC WD1600AAJS-75WAA0
WDC WD1600AAJS-75WAA0.zip [2.63 MiB]
Downloaded 446 times
ACELab partner
PostPosted: November 8th, 2012, 5:56
Sorry dont have that one
PostPosted: November 8th, 2012, 7:36
pclab, thanks, but it is not compatible.
northwind, no problem. thanks
I'm still searching for this module.
PostPosted: November 8th, 2012, 14:07
No sorry, only 500F0 and 500FC
PostPosted: November 9th, 2012, 1:10
pcimage, may I try both ?
thanks
PostPosted: November 13th, 2012, 8:25
Data recovered 100%. Successful case :D
I have saved and uploaded the SA here : http://files.hddguru.com/download/PC-30 ... 464320.pcr
PostPosted: November 13th, 2012, 9:53
Good job :)
