 Post subject: WD3200AAKS-00UU3A0
PostPosted: November 13th, 2012, 17:17
More info:
WD3200AAKS-00UU3A0
Date: 05 MAY 2010
DCM: HGNNTJAHN
If you need any other number, I will provide them
Thanks in advanced,
 Post subject: Re: WD3200AAKS-00UU3A0
PostPosted: November 14th, 2012, 3:59
Selling?
PostPosted: November 15th, 2012, 14:34
LOL sorry, I meant need the Loader for it.
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 2
Cyl Count............................... : 256
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 192 Kb
ROM version............................. : 00.0JB
ROM generation.......................... : 00.0JB
Link table version...................... : 03.0B.
Consolidated ROM version................ : 0000000J
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 156 336 (24)
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads number in use..................... : 2
Switched off heads...................... : No
Heads map............................... : 0,1
ROM Firmware version.................... : 0000000J
View module 90 information
Total heads............................. : 2
Used heads.............................. : 2
Mdl 47 version.......................... : FU.0021
ROM Version version..................... : 0000000J (00.0J)
Mdl 11 Version.......................... : 0000000J (00.0J)
PostPosted: November 15th, 2012, 16:39
i thought as northwind you wanna sell or buy , :lol: plz next time try to be more specifically
11.rar [367.2 KiB]
Downloaded 457 times
Tawfeek Mokhtar
http://alsafwapc.net
Alsafwa Data Recovery Egypt
PostPosted: November 15th, 2012, 17:08
Thanks. Worked perfectly.
