WD5000BMVV-11SXZS1
Posted: December 4th, 2012, 19:06
by newtontr
Hi, I've found that the head crash
My Haddiskim:
WD5000BMVV-11SXZS1
R / N 771754
Date 29 JAN 2011
DCM: HHCVJHB
DCX: RS19X1FZ8
A 500 GB hard drive. This disc had found on the Internet searching for donors. (
http://www.harddrivesforsale.com/wd5000 ... zs1-2.html)
Donor:
MDL: WD5000BMVV-11SXZS1
S / N: WX21A4196717
Date: 20 MAY 2011
DCM: HAOTJVN
DCX: 9S11X4FZ6
Do you think is appropriate donor hard disk head?
Re: WD5000BMVV-11SXZS1
Posted: December 5th, 2012, 3:57
by northwind
Judging by the question, I guess you are not experienced in head swaps and data recovery in general.
Are you sure you want to do this yourself? With that particular drive, chances of success are... zero?
PS. You are willing to spend $200 for a donor but you won't consider pro help?
Posted: December 5th, 2012, 5:15
by newtontr
northwind wrote:Judging by the question, I guess you are not experienced in head swaps and data recovery in general.
Can you tell me why is not suitable donor?
Posted: December 5th, 2012, 7:17
by northwind
I didn't say it isn't.
I said it will not work if YOU do it.
Posted: December 5th, 2012, 7:59
by hddguy
Northwind is right. Even if you have diagnosed it right, and even if the head change goes well, you will struggle to extract the data without specialist equipment to maintain stability and compensate for read errors and slow surface access which is very common after such repairs...
Posted: December 5th, 2012, 9:03
by newtontr
I have a clean room and equipment
Posted: December 5th, 2012, 9:35
by hddguy
What equipment?
Posted: December 5th, 2012, 10:04
by newtontr
Hddsurgery brand head replacement tools
Posted: December 5th, 2012, 10:13
by hddguy
I think you missed my point......
In short, the donor part is compatible enough. Try at your own risk.
Posted: December 5th, 2012, 10:15
by newtontr
Thank you hddguy .
