Model : ST31500341AS
http://forum.hddguru.com/viewtopic.php?f=11&t=24898
Author:  DRCP [ January 5th, 2013, 13:11 ]
Post subject:  Model : ST31500341AS
Hello Gurus
i have following hdd
Serial : 9VS372TK
Firmware : CC1H
Capacity : 1 397.27 GB (2 930 277 168)
It was in busy state.
i tried busy state solution and it resolved
but if i tried partition analysis ,showing data green Z icon (pic attached)
this hdd is attached as secondary (as i discussed with customer he said no encryption,no raid,no hdd password)
So please guide.
Author:  labtech [ January 5th, 2013, 15:41 ]
Post subject:  Re: Model : ST31500341AS
How was the drive used by the customer? In an external? What kind of system? Any other details?
Author:  DRCP [ January 5th, 2013, 23:27 ]
Its internal HDD .Connected secondary HDD for data storage(with single partition on win XP)
Even if i tried raw recovery its shows data but unable to open
Author:  pcimage [ January 6th, 2013, 6:23 ]
Can you read LBA's all the way to the end of the drive?
Author:  DRCP [ January 6th, 2013, 6:41 ]
yes i can read
Author:  einstein9 [ January 6th, 2013, 7:40 ]
DRCP wrote:
yes i can read
when u tried RAW did you get working JPG`s (for example) or all damaged?
(since i hate seagate, i prefer in such case to CLONE IT) then do whatever you are doing)
IF jpg`s are ALL DAMAGED IN RAW, i can think only of 1 things = ur client.
good luck
Author:  pcimage [ January 6th, 2013, 7:44 ]
Clone it as per einstein9's sensible suggestion.
Then scan it with other recovery sw such as rstudio, UFS explorer, GDB etc...
Author:  DRCP [ January 6th, 2013, 11:06 ]
problem resolved thanks gurus
Author:  pcimage [ January 6th, 2013, 11:13 ]
What was the issue?
Author:  DRCP [ January 6th, 2013, 11:34 ]
i again discussed with customer ,he said that drive is compressed drive.
initially just i tried raw recovery and checked some jpg files which was currupt.
then i found Z represents for zip so i recovered some folders which was dcm files so cant open with regular viewer its showing corrupt files (due to that reason i confused and whole hdd contains only dcm files)
then i installed DCM viewer and checked data .(all ok)
thanks gurus for kindly help specially labtech,pcimage & einstein9 (the super gurus helping us )
