 Post subject: Needed Module 11 for WD2500BEVT-75A23T0 Jamaica
PostPosted: January 8th, 2013, 7:03
I need LDR file for:
ROM: ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 16.1QQ
ROM generation.......................... : 16.1QQ
Link table version...................... : 07.22.
Consolidated ROM version................ : 0016001Q
 Post subject: Re: Needed Module 11 for WD2500BEVT-75A23T0 Jamaica
PostPosted: January 9th, 2013, 5:24
Try this, might get lucky :-) ..
>Techno mode key
>Techno mode key......................... : Ok
>RAM:
>HDD Info reading........................ : Ok
>Heads number............................ : 2
>Cyl Count............................... : 256
>Zone allocation table................... : Ok
>SA SPT.................................. : 1102
>ROM:
>ROM version............................. : 16.01Q
>ROM generation.......................... : 16.01Q
>Link table version...................... : 08.02.
>Consolidated ROM version................ : 00160001
>ROM Modules:
>Flash ROM dir reading................... : Ok
>Modules directory address............... : FIXED
>SA regions address...................... : by default
>SA Translator loading................... : Ok
>Heads configuration..................... : by map
>Heads number in use..................... : 2
>Switched off heads...................... : No
>Heads map............................... : 0,1
>ROM Firmware version.................... : 00160001
>Service area:
>SA dir reading (ID)..................... : Ok
>SA Access............................... : Copy 0,Copy 1
11.rar [171.76 KiB]
Downloaded 509 times
PostPosted: January 9th, 2013, 5:30
Or this?...
>Techno mode key
>RAM:
>SA SPT.................................. : 881
>ROM:
>Flash Dir reading....................... : Ok
>ROM version............................. : 16.0QD
>ROM generation.......................... : 16.0QD
>Link table version...................... : 00.1F.
>Heads number............................ : 3
>Switched off heads...................... : Yes
>Head map................................ : 2,3
>ROM Firmware version.................... : 0016000Q
>Service area:
>SA dir reading.......................... : Ok
>SA Copies avalabled..................... : Copy 0,Copy 1
>Configuration reading................... : Ok
>Master Password......................... : has not been set
>User Password........................... : has not been set
PostPosted: January 9th, 2013, 17:47
Thank you Sean. I will try :)
PostPosted: January 12th, 2013, 20:04
Unfortunately don't fit. So I'm still looking...
Users browsing this forum: No registered users and 14 guests
