Seagate PCB 100645422 Short Points
http://forum.hddguru.com/viewtopic.php?f=11&t=25039
Author:  Cleanroom [ January 16th, 2013, 12:36 ]
Post subject:  Seagate PCB 100645422 Short Points
Does anyone know the short-out point for this board
Model number ST2000DM001
The ace manuals do not have that one listed yet.
I attached a zip of the front and back of the board.
100645422.zip [777.38 KiB]
Downloaded 1103 times
Author:  labtech [ January 16th, 2013, 12:42 ]
Post subject:  Re: Seagate PCB 100645422 Short Points
ACE TS does not know?
Author:  Cleanroom [ January 16th, 2013, 12:48 ]
I asked on the forums already, just their response is never great, so I thought i would ask here as well.
Author:  lcoughey [ January 16th, 2013, 15:31 ]
ACE forums are useless for tech support. You pretty much need to contact them via Skype in order to get a straight answer.
Author:  Cleanroom [ January 16th, 2013, 16:50 ]
I will try in the morning if there is no response by then.
Author:  einstein9 [ January 18th, 2013, 7:17 ]
PM Sent.. :wink:
Author:  coolmac [ February 23rd, 2013, 13:32 ]
Hi,buddy ,same question .could u send me a PM about short-out point on that PCB?really appreciate !
Author:  polanwu [ February 28th, 2013, 11:54 ]
I know this, but I do not want to overt, if you need to, you can give me an E-mail and I will tell you the method!
polanwu@163.com
Author:  andreidi [ November 11th, 2013, 16:53 ]
Can I have a PM with those shorting point and method, please? Or maybe an e-mail: bucovina_bloodhand@hotmail.com
Thanks!
Author:  fzabkar [ November 12th, 2013, 3:17 ]
If you mean the read channel, see the following:
Tip: How to identify the Read Channel test points:
http://malthus.zapto.org/viewtopic.php? ... 123&p=1632
Author:  billyk1 [ April 27th, 2014, 11:25 ]
Hello
could someone help me? I ve spent times trying toi get the CTRL Z working, and it seems that I need to find and short the read channel. But I have no idea where it is on the board. An image with the exact points should be great.
Cheers (ST2000MD001)
Author:  chamxz [ July 16th, 2014, 19:13 ]
billyk1 wrote:
Hello
File comment: Here good luck
