 Post subject: WD30EZRX
PostPosted: January 28th, 2013, 3:20
WD30EZRX
3.0 TB
initially in busy state making noise like head stuck
when i run WD utility following log
Techno mode key
Techno mode key:........................ : Techno key error; unexpected error: Drive is not ready
Debug Stop Code......................... : HOST DEBUGSTOP RESET TIMEOUT
RAM:
HDD Info reading........................ : HDDs RAM reading error - Device Error Detected: "VSCE VSC MODE DISABLED"
ROM:
ROM reading............................. : Ok
ROM Data size........................... : 256 Kb
ROM version............................. : 20.1UP
ROM generation.......................... : 20.1UP
Link table version...................... : 0B.38.
Consolidated ROM version................ : 0020001U
ROM Modules:
Flash ROM dir reading................... : Ok
Flash ROM dir (ext) reading............. : Ok (Active)
Modules directory address............... : 283 719 (24)
SA regions address...................... : by default
SA Translator loading................... : Ok
Heads number............................ : 8
Heads number in use..................... : 8
Switched off heads...................... : No
Heads map............................... : 0,1,2,3,4,5,6,7
ROM Firmware version.................... : 0020001U
Is it FW issue?
 Post subject: Re: WD30EZRX
PostPosted: January 28th, 2013, 3:26
Motor start?
PostPosted: January 28th, 2013, 3:28
yes motor starts
PostPosted: January 28th, 2013, 4:35
BSY bug on this model is typical, but I'm a little puzzled about the noises you mention.
Can you describe? Clicking? Buzzing? Or are they just typical calibration noises?
PostPosted: January 28th, 2013, 8:14
no clicking and buzzing it likes calibration noise
PostPosted: January 28th, 2013, 8:18
if i put hdd on in after 2 mins err glows and hdd spin down
PostPosted: January 28th, 2013, 9:05
calibration noise = normal.
I believe this is typical BSY bug for this series.
PostPosted: January 28th, 2013, 10:37
what is soln?
PostPosted: January 28th, 2013, 11:43
I am not allowed to disclose such information in public, but i will PM you and try to help.
PostPosted: January 31st, 2013, 11:44
Access to ACE boards will grant you access to the sticky that explains how to get into these drives to check SA/heads in most cases.
I can PM you if others have not already answered your question, just shoot me a PM.
also, you need one of the latest releases of PC3K for this to work, like the last 2 tops I think.
Regards,
PostPosted: April 30th, 2015, 22:13
Hi guys,
I need help with a simliar western digital hard drive. Same problem, in PC-3000 Express its stuck on "BSY". Its a 3.5" WD Caviar Green WD30EZRS-00J99B0 3TB. With kernel mode, I was able to read the below out of the hard. Thanks.
Techno mode key
Techno mode key......................... : Ok
RAM:
HDD Info reading........................ : Ok
Heads number............................ : 1
Cyl Count............................... : 192
ROM:
Flash ROM dir reading (Ext)............. : Ok (Active)
ROM Modules:
ROM F/W version......................... : 0020001U
Overlay F/W version..................... : 20.1UP
Servo F/W version....................... : 0B.38
PostPosted: June 30th, 2015, 6:24
Regards,
Would you mind to send me a PM too regarding this information? This BSY error is getting on my nerves.
Users browsing this forum: Google [Bot] and 18 guests
