| WD30EZRX http://forum.hddguru.com/viewtopic.php?f=11&t=25155 |
Page 1 of 1 |
| Author: | DRCP [ January 28th, 2013, 3:20 ] |
| Post subject: | WD30EZRX |
WD30EZRX 3.0 TB initially in busy state making noise like head stuck when i run WD utility following log Techno mode key Techno mode key:........................ : Techno key error; unexpected error: Drive is not ready Debug Stop Code......................... : HOST DEBUGSTOP RESET TIMEOUT RAM: HDD Info reading........................ : HDDs RAM reading error - Device Error Detected: "VSCE VSC MODE DISABLED" ROM: ROM reading............................. : Ok ROM Data size........................... : 256 Kb ROM version............................. : 20.1UP ROM generation.......................... : 20.1UP Link table version...................... : 0B.38. Consolidated ROM version................ : 0020001U ROM Modules: Flash ROM dir reading................... : Ok Flash ROM dir (ext) reading............. : Ok (Active) Modules directory address............... : 283 719 (24) SA regions address...................... : by default SA Translator loading................... : Ok Heads configuration..................... : by map Heads number............................ : 8 Heads number in use..................... : 8 Switched off heads...................... : No Heads map............................... : 0,1,2,3,4,5,6,7 ROM Firmware version.................... : 0020001U Is it FW issue? |
| Author: | arvika [ January 28th, 2013, 3:26 ] |
| Post subject: | Re: WD30EZRX |
Motor start? |
| Author: | DRCP [ January 28th, 2013, 3:28 ] |
yes motor starts |
| Author: | northwind [ January 28th, 2013, 4:35 ] |
BSY bug on this model is typical, but I'm a little puzzled about the noises you mention. Can you describe? Clicking? Buzzing? Or are they just typical calibration noises? |
| Author: | DRCP [ January 28th, 2013, 8:14 ] |
Can you describe? Clicking? Buzzing? Or are they just typical calibration noises? no clicking and buzzing it likes calibration noise |
| Author: | DRCP [ January 28th, 2013, 8:18 ] |
if i put hdd on in after 2 mins err glows and hdd spin down |
| Author: | northwind [ January 28th, 2013, 9:05 ] |
calibration noise = normal. I believe this is typical BSY bug for this series. |
| Author: | DRCP [ January 28th, 2013, 10:37 ] |
what is soln? |
| Author: | northwind [ January 28th, 2013, 11:43 ] |
I am not allowed to disclose such information in public, but i will PM you and try to help. |
| Author: | Russwinters [ January 31st, 2013, 11:44 ] |
Access to ACE boards will grant you access to the sticky that explains how to get into these drives to check SA/heads in most cases. I can PM you if others have not already answered your question, just shoot me a PM. also, you need one of the latest releases of PC3K for this to work, like the last 2 tops I think. Regards, |
| Author: | profix [ April 30th, 2015, 22:13 ] |
Hi guys, I need help with a simliar western digital hard drive. Same problem, in PC-3000 Express its stuck on "BSY". Its a 3.5" WD Caviar Green WD30EZRS-00J99B0 3TB. With kernel mode, I was able to read the below out of the hard. Thanks. Techno mode key Techno mode key......................... : Ok RAM: HDD Info reading........................ : Ok Heads number............................ : 1 Cyl Count............................... : 192 ROM: ROM reading............................. : Ok ROM Data size........................... : 256 Kb Flash ROM dir reading................... : Ok Flash ROM dir reading (Ext)............. : Ok (Active) Modules directory address............... : 283 719 SA regions address...................... : by default SA Translator loading................... : Ok ROM Modules: ROM version............................. : 20.1UP ROM F/W version......................... : 0020001U Overlay F/W version..................... : 20.1UP Servo F/W version....................... : 0B.38 Heads configuration..................... : by map Heads number............................ : 8 Heads number in use..................... : 8 Switched off heads...................... : No Heads map............................... : 0,1,2,3,4,5,6,7 |
| Author: | minimalist [ June 30th, 2015, 6:24 ] |
Russwinters wrote: Access to ACE boards will grant you access to the sticky that explains how to get into these drives to check SA/heads in most cases. I can PM you if others have not already answered your question, just shoot me a PM. also, you need one of the latest releases of PC3K for this to work, like the last 2 tops I think. Regards, Would you mind to send me a PM too regarding this information? This BSY error is getting on my nerves. |
