 Post subject: Error code: 4343
PostPosted: February 11th, 2013, 6:04
Hello to you all,
We have WD800JD-22LSA0 HDD, and on PC-3000 we get the following error:
SA dir reading (ID)..................... : Unknown error. Error code: 4343
Configuration reading................... : Module 02 not found
we replaced the bord, after that we replaced the heads.
the HDD is spinning, makes 3 clicks sound and power off.
We returned the heads to the donor drive, and the donor head works fine.
So it turns out that the customer platter is clen.
Does anyone experience such a case?
anyone have an idea?
 Post subject: Re: Error code: 4343
PostPosted: February 11th, 2013, 16:45
Very tricky head swaps on this model.
I mean its easy to swap the heads, but there are tricks to get them to work!
PostPosted: February 12th, 2013, 4:26
There is a trick you can specifically recommend for this model ?
PostPosted: February 12th, 2013, 14:05
Yes, oscilloscope, to check servo.
Angel Data Recovery
Users browsing this forum: No registered users and 62 guests
